Colors can be clipped outside of neutral or something that is not white weird that you don't know this
And you do realize that what your are trying to show is nothing more than where a color falls within a values of 0,0,0 to 255,255,255 in a given color space and not what is contained within a raw file
Other than the hidden adjustments being done without you know so then yes, but if you use RD you would know what adjustments are being done without your knowledge.
Has anyone considered that this may be a wind up? Lots of it in DPReview forums, perhaps it has migrated here. If it is not then I apologise to the OP. Ken
Yup maybe you should
"Rather generally, RawDigger is a very useful resource for gaining meaningful information in relation to shooting ETTR. With RawDigger you can see the actual raw histograms and see exactly how closely you have achieved ETTR."
"White balance also affects the histograms, sometimes resulting in a story that differs greatly from that of the underlying raw-data histograms and therefore potentially providing misleading information for ETTR."
"The amount of highlight headroom varies from camera to camera, and you will have to experiment with your camera to determine whether you have 2-2/3, 3, or even more EV of headroom. You can determine this amount quite accurately by using software like Rawdigger"
This is what is hidden to you with the raw converters with the BLE and other processing
and the last quote
"And it provides accurate feedback about the efficacy of your ETTR techniques. It is, therefore, highly recommended software for any raw shooter wanting to perfect using ETTR."
I have and others have been saying this all along
I don't think you even read what you linked to
and certainly not anything people have been telling you here
conclusion: thanks for the discussion but needed to know how good my studio exposures were using another program.
I will not be adjusting my work flow because my images show "PERFECT EXPOSURE" using the in camera A74 histogram.
If you want to debate it further then dont include me. as im now brain dead after a record 230 posts 😵💫😵💫😵💫
The combination of f-number and exposure time expressed logarithmically to base 2. What you probably think of as 'EV' is properly EV₁₀₀ , which is the scene luminance which gives nominal (target) exposure with the given EV setting. It's an alternative to the correct SI unit, the lux, which in my view is preferable.
yes i was referring ev on the raw digger histogram as the figure "0" and after reading the info on there site and at DPR i was right as the histogram is in Photographic mode. or whatever it is.
Your raw data was 2 stops underexposed as shown by the histogram you posted.
If that meets your definition of "perfect exposure" that's fine as it is your choice to make but my definition of perfect exposure is the optimal exposure** which is clearly different to your definition.
sorry mate that was from another image. im referring to the dancer i posted with the accompanying histogram. i sent a link to Ian so he could have a play with the image of the dancer not the other one was just a selfie of me .
sorry for the confusion ,its hard with the forum configuration as to what im posting to, its getting a bit confusing.
